I uninstalled cm launcher but it's still running on my phone. I've tried force stop with my battery saver app but it continues to run. How do I delete it off my phone?
Welcome to Android Central! Which phone? Did it successfully uninstall? Go to Settings>Security>Device Administrators. Is it listed there and checked on? If so, uncheck it, and then see if you can uninstall it again.
