How do I delete posts? I see where I can edit but not delete. Hopefully this can be answered before it gets deleted again by someone first lol
You can only delete posts after you reach a certain level of posting (at least past 10). I don't recall what that is as it was some time ago. Best thing to do is edit the post. If it's a double post just put that.
Once you reach the level you can delete, it's in the Advance editing.
If you're using the forums app, I don't think there is a delete option even after hitting the required amount of posts.
As far as I know: Ordinary members can Not delete posts
But can Edit them. If after Sent and Read it discover errors
Can be Edited, but Not always work. I've done it few
times. But when sent it..Create double posts
The last time I think a Mod-Spotted my duplicate Posts & deleted
one. In most forums the Mods-Take care of it..So is better
Double review posts, before Submited: Is my opinion
With the permission of the OP=Jewels81: Thanks again to the
Gent's N_LaRue and JavierP : I've no doubt that your method works
But for unknown reason. When I login that "Duplicate thread" in
AC-Desktop ver. clicked the [Edit] button-don't let Me delete them
So to JavierP or any Mod. Pull the "Delete-Tool" Hehe! and
remove the last 3-Posts on this thread: Keep my 1st-Post only
link: http://forums.androidcentral.com/samsung-galaxy-s7/685925-removed-music-sgs7-phone-when-started.html
Sorry about that: Just to be straigh forward. I didn't explain properly
What I need is to "Delete" 3Posts out of 4: As you can see if you
open the Link-Provided there're 4Replies by Sam-Gs7..
When follow your Advice: I click on the "Edit" button from the
Post that I want to Delete, but nothing happens. That's why
I've requeted help. Hope Javier give it Try on too..Bye
