I'm new to Android, so please forgive me if this is a stupid question!
I have installed and formatted an SD card in an Android Lollipop smartphone. However, I am unable to copy files (using ES File Explorer) from the internal memory (SD0) to the SD card (SD1): when I perform the copy operation, although ES File Explorer reports that the file was successfully copied to SD1, the file does not appear on the SD drive, but a second copy of the file has been created in the internal memory!
And I'm having similar problems moving apps to the SD card: when I use the Android app manager (clicking on "Move to SD card"), the app manager reports that the app is now on the SD card, but ES File Explorer shows the files still in the internal memory.
Can anyone cast any light on this, please?
