1. SilverRocket88's Avatar
    Hey.
    Using Google Keep....
    I deleted a note and also emptied the bin few weeks ago and I'm just wondering if it's possible to restore at all?
    It displays a message when emptying the bin saying "All notes in recycle bin will be permanently deleted" so is that it? Once it's gone it's gone....
    I feel like there might be a way???
    Any help or clarification would be great.
    Nevermind if there's not a way... I only wanted to restore them so that I could instead mark them as 'Done' within the Google Inbox app and keep them there for reference if I ever needed them....
    Thanks.
    08-30-2016 03:59 PM
  2. B. Diddy's Avatar
    They're supposed to be recoverable in the Bin for 7 days, but then afterwards, they're gone. It's often recommended to Archive instead of Delete, since the Archive is always recoverable. Sorry!
    SilverRocket88 likes this.
    08-30-2016 06:25 PM
  3. SilverRocket88's Avatar
    Ah right ok, It's no big issue anyway, i don't really need the deleted message. It just would have been useful to know if i could restore the message and then use Google Inbox (as it integrates with Google Keep) to "Mark it as Done" and then have the message saved there as a sort of archive (as explained in my above post)
    But nevermind
    Thanks for your reply.
    B. Diddy likes this.
    10-29-2016 12:30 PM
  1. Should the 6p be the last Nexus brand phone
    By MDMcAtee in forum Nexus 6P
    Last Post: 09-02-2016, 05:35 PM
  2. How safe is this file?
    By sulasno in forum Ask a Question
    Last Post: 09-01-2016, 06:34 AM
  3. Is there a way to take a picture of your always on screen?
    By catloverplayer in forum Samsung Galaxy Note 7
    Last Post: 08-30-2016, 04:26 PM
  4. Unable to connect vpn
    Last Post: 08-30-2016, 03:52 PM
  5. Replies: 0
    Last Post: 08-30-2016, 03:28 PM
