1. Metaphysical Grace's Avatar
    Looked in settings and online. Don't want to use the Always on Feature. Just want to move the clock so its not on my wife and daughters face that i have as the background. Also don't want to resize the image. Just need a yes i can with a step by step on how, or a no its not a feature yet.
    08-30-2016 04:54 PM
  2. SpookDroid's Avatar
    If you mean the digital clock on the lockscreen, then nope, you can' move or resize that. If you mean the clock on your homescreen, that's a widget, and you can remove it and (if your launcher supports it, not sure if TouchWiz does or not) you should be able to resize it. Just tap and hold on it and either move to the trash icon or resize accordingly.
    08-30-2016 04:59 PM
  1. why is my hotspot turning itself off 15 - 20 or so mins
    Last Post: 10-27-2016, 05:59 PM
  2. I only recieves messages when I open the whatsapp or bbm app
    Last Post: 08-31-2016, 11:53 AM
  3. how do you log in to listen to your voice mail
    Last Post: 08-30-2016, 04:59 PM
  4. Replies: 0
    Last Post: 08-30-2016, 04:49 PM
  5. Alarm Clock always starts with yet another new alarm?
    By jimojimo in forum Samsung Galaxy S7
    Last Post: 08-30-2016, 04:37 PM
