1. wokinglad's Avatar
    Hi guys
    I was v. close to ordering either a LeEco or ZUK smartphone via Oppomart or some other retailer, until it suddenly struck me that whilst the device should work fine here, am i right in thinking it wont receive any OTA updates to software, as network operators send them out, and none here support those devices? Thx
    P.S im in the UK
    09-05-2016 03:21 AM
  2. dexterouz's Avatar
    I am not from the UK but I think since it will unlocked, you will receive OTA via their respective Updater app/option.
    09-05-2016 10:15 AM
  3. wokinglad's Avatar
    As far as i know, updates were sent out by operators though? UK operators wont be sending out updates for these phones ?
    09-05-2016 02:13 PM
  1. [Free][Android] Ocean Live Wallpaper
    By WMDS in forum Android Apps
    Last Post: 09-13-2016, 01:06 AM
  2. Disable Two-Step Authentication to Setup Android?
    By Father Tech in forum General Help and How To
    Last Post: 09-09-2016, 11:42 AM
  3. why wont my phone turn on
    Last Post: 09-05-2016, 02:35 AM
  4. moto X phone unlocking
    Last Post: 09-04-2016, 11:39 PM
