1. FoxAlive's Avatar
    Hello, everybody. I have traveled vast worlds in search of answers... no, seriously... half the time my phone won't download mms, or group texts. I grow weary of it and was hoping somebody could help me. I have the ability to download it, but for some reason the phone acts screwy. That being said, sometimes people have to send the mms 3-4 times in order for it to go through. I greatly appreciate any and all help. Thank you!
    09-18-2016 03:55 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which carrier do you have? Are the APN settings correct for that carrier? Is your mobile data signal always good? MMS requires mobile data, so if that signal is spotty, you might have trouble receiving some of the messages.
    09-19-2016 03:17 AM
  3. FoxAlive's Avatar
    Thank you, B. Diddy. I am using Straight Talk, I have no idea if they are as I have bought the phone used. Yes, my signal is almost always good. When I am in bad spots, I can understand, but I have fine service.
    09-19-2016 05:49 PM
  4. B. Diddy's Avatar
    Go to Settings>Mobile Networks>Access Point Names, select the one you're using, and edit it. Make sure they're set to the following: Straight talk apn settings – Dummy proof guide
    09-19-2016 09:20 PM
  5. FoxAlive's Avatar
    All right, I followed the instructions to the letter! So, I will test how this goes and give it a couple days! Thank you so much for your help, though!
    B. Diddy likes this.
    09-19-2016 10:34 PM
  1. Upgrade to Note 5 from S5?
    By Ronan1287 in forum Samsung Galaxy Note 5
    Last Post: 09-19-2016, 09:45 PM
  2. how to transfer data to larger sd card samsung s4
    Last Post: 09-18-2016, 04:32 PM
  3. Odin wont install anything to my Samsung Galaxy S2
    Last Post: 09-18-2016, 02:59 PM
  4. Samsung galaxy s5 mini g800h
    Last Post: 09-18-2016, 02:35 PM
  5. Why did Kies stop connecting my Note 4?
    Last Post: 09-18-2016, 02:10 PM
