Galaxy J1 Ace stuck in download mode
srkmagnus
Retired Moderator
May 23, 2010
13,434
210
Re: Why is my phone stack in download mode
Odin Mode (Multi Core Download)
Product Name :SM-J110F
CURRENT BINARY : Samsung Official
SYSTEM STATUS: Custom
Secure download: Enabled
Try long-pressing the power button to force it to reboot. If that doesn’t reboot then remove the battery and re-insert it. Try to boot. While doing all of this make sure you are disconnected from the computer.
myekstarcy
I also have same problem with j110F.i tried repairing it using smart switch,it didnt work.i tried the stock rom using odin,it says PIT file failed.i flash another PIT file of J110f,not successful. I took it to samsung store and still they couldnt fix it.i still like this phone.pls help me :( (Email address removed by moderator)
