1. Hartkopf rc's Avatar
    When I want to connect to our Wi-Fi at work with my smartphone a Verssed vp2.1 it show a "authentication Problem"
    The password is not the problem. I have my tablet next to me with no connection problems like this.
    How can I fix this ? it seems like a problem all over.
    Thanks
    10-03-2016 06:24 AM
  2. SpookDroid's Avatar
    Is it only happening on that particular network? If so, is there a portal that you have to go through to authenticate? Maybe you have to re-log in there.
    I would also try to 'forget' the network from your phone and re-add it, making sure that the credentials are correct.
    10-03-2016 10:07 AM
  1. "There was a problem communicating with Google servers try again later."
    By AlexAndriod in forum Legacy Android & Other OS's
    Last Post: 10-16-2016, 02:03 AM
  2. Nexus 6p Bootup Problem
    By BaxterCooper in forum Ask a Question
    Last Post: 10-05-2016, 07:50 PM
  3. Android maxx recording problems with an app that has a camera
    Last Post: 10-03-2016, 02:24 AM
  4. Problem with call volume !
    By granjamania in forum Moto G
    Last Post: 10-03-2016, 01:18 AM
  5. Replies: 2
    Last Post: 10-02-2016, 09:46 PM
