1. Mooserman15's Avatar
    My tablet (gt-p5113) is getting hot. The heat you would expect from playing intense games, except it happens whenever I am using the tablet at all. The tablet is not laggy. The battery life is normal. I can tell that the heat is coming from the CPU, not the battery. This has never happened before.
    10-05-2016 10:19 PM
  2. B. Diddy's Avatar
    It would help to see the battery stats when this happens. Let it occur for a little while, then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time).
    10-06-2016 02:13 PM
  3. Mooserman15's Avatar
    Both screens look perfectly normal.
    My tablet is hot for absolutely no reason.-screenshot_2016-10-07-22-58-00.png
    My tablet is hot for absolutely no reason.-screenshot_2016-10-07-22-57-26.png
    10-08-2016 01:03 AM
  4. B. Diddy's Avatar
    And where in that graph corresponds to when the tablet is getting hot? Is it only when the screen is on, or even when it's idle?
    There should also be somewhere you can see how much battery % each app is using--can you show us that?
    10-08-2016 09:22 AM
  5. Mooserman15's Avatar
    My tablet gets hot when it is in use. And I did show you the screen showing how much % each app is using. That is the second screenshot. No apps were consuming battery. None at all.
    10-09-2016 04:05 PM
  6. B. Diddy's Avatar
    Hmm. That second screenshot is very unusual, because even if no apps are being used, something will still be using battery (like Android OS or System). Is your tablet rooted? Have you tried wiping the cache partition? http://forums.androidcentral.com/sam...2-s3-tab2.html
    10-11-2016 02:11 AM
  7. Mooserman15's Avatar
    Yep, it is rooted.. I did not wipe the cach partition. I just got TWRP, and running TWRP fixed my tablet. I will wipe the cache partition today.
    B. Diddy likes this.
    10-14-2016 08:40 AM
  8. B. Diddy's Avatar
    If it's no longer running hot, then there's no need to wipe the cache (although it shouldn't hurt anything either).
    10-14-2016 10:43 AM
  1. My samsung galaxy core is in odin mode
    By Superdave2003 in forum Samsung Galaxy Core
    Last Post: 10-06-2016, 05:43 PM
  2. Samsung tablet TouchWhizisn't responding
    Last Post: 10-06-2016, 04:54 AM
  3. Mobile data is not switching on my mobile micromax E471
    Last Post: 10-06-2016, 04:52 AM
  4. What is the best free Android app for WiFi only texting?
    Last Post: 10-06-2016, 12:01 AM
  5. Why won't my android phone ring
    Last Post: 10-05-2016, 09:09 PM
Tags for this Thread
