Hi, I remember back to how easy file transfer used to be on android. Just plug in usb, treat it like any other sd card and drag and drop files wherever I pleased.
So simple, so easy.
Note I have a note 3 and that doesn't work any more!
I have to use Samsungs software and it just gets in the way and makes things more difficult! I feel like an iphone user trapped in itunes!
So my first question is: is there a way to return to the old drag and drop way (even if it's via an app).
My second question is: why are they doing this? i.e. what's in it for them (since it obviously doesn't help the user any)?
Thanks!
Edit (can't seem to reply?): I use osx (think mountain lion?)
10-11-2016 04:31 AM
