1. Eijin's Avatar
    Hi recently i have quite complicated problem with my note 4. Problem started to occur couple weeks ago. I couldn't be heard even if I shouted when making calls. only loudspeaker worked. While recording voice and playedback the sound was very weak. I have performed factory reset and cleared cache partition but it didn't work.
    Yesterday when I made a call I suddenly could have been be heard but again loudspeaker didn't work. Very frequently during the call my voice dissappeared so the other person couldn't hear me but when I have turned the loudspeaker on and off immediately I could have been heard for a while. I had to do this few times during the call but my microphone somehow worked for short periods. So to me it seems like it's more like a software issue rather than hardware. Hopefully. Altough it's weird the factory reset didn't help.
    Appreciate any advice altough it is dodgy one I guess.
    10-12-2016 07:19 AM
  2. thisbearisdrunk's Avatar
    did u drop it on the floor? or did u try blowing on the microphone ??
    10-12-2016 07:51 AM
  3. Eijin's Avatar
    Yeah I have dropped it but I wouldn't like to suggest it may be a reason...
    10-12-2016 10:41 AM
  4. JulianDevi's Avatar
    I am having a similar issue however mine is dealing with no audio being transmitted through the headphone port on my T-mobile note 4. I didn't notice this issue until after the 6.0.1 update and some other security upgrades. I called Samsung and they advised me to come in to re-flash the software however I can do that myself. Note: This issue of no sound from my headphone port on my note 4 is persisting even after I have replaced the old headphone port with a new one and factory reset the device. Any suggestions or advice would be helpful. I can get a brand new phone as I'm still under warranty with Samsung and t-mobile however I'd much rather prefer fixing and keeping my old one! <3 ?????????
    10-13-2016 06:28 AM
  1. Replies: 55
    Last Post: 10-13-2016, 10:42 PM
  2. Replies: 17
    Last Post: 10-13-2016, 11:29 AM
  3. Can't rename a folder on Note 3 via PC Windows
    Last Post: 10-12-2016, 08:40 AM
  4. Pervasive problems with S6 acting up (description in post)
    By DroidMudkip in forum Samsung Galaxy S6
    Last Post: 10-12-2016, 04:56 AM
  5. Can I use my Note 7 charger with HTC 10?
    Last Post: 10-12-2016, 01:41 AM
