1. susan502's Avatar
    I am careful in handling the chargers especially when they cost 20.00. In past 4 months i have been through 4 chargers. And they are not easy to find in stores. I realized that you can use just the smaller port to charge ( takes longer) Is this something that happens to others? I cant keep buying chargers. Do they make flat surface chargers ? it would be easier.
    10-22-2016 12:00 PM
  2. Rukbat's Avatar
    No one makes the old Motorola flat face chargers, but it sounds as if you're rough on them. I have 2 Samsung chargers plugged into my power strip and they've been there for over 3 years - and never broken. But I'm reasonably careful with them. (And Samsung Micro-USB 2A Travel Charger - Android Wall Chargers - ShopAndroid is only $13.)
    10-22-2016 03:38 PM
  3. iOS Gravity's Avatar
    You're probably really rough with the chargers... I know someone who has bent their S5 charging wire multiple times for it to reach from the wall to where they were sitting and it hasn't broken in 2 years.
    10-22-2016 04:37 PM
  1. Replies: 1
    Last Post: 10-22-2016, 03:31 PM
  2. Pop up ads on my samsung phone
    Last Post: 10-22-2016, 01:56 PM
  3. Why wont my ringtone play?
    Last Post: 10-22-2016, 01:53 PM
  4. can you replace my samsung 7 edge ??
    Last Post: 10-22-2016, 11:58 AM
