1. tenenboim's Avatar
    I'm starting to get desparate: my tablet (Android 5.1) restarts spontaneously now and then.
    It usually happens while playing graphics-intensive games. After a factory reset, followed by careful, stepwise installation of apps, I seemed to have located the culprit: Google Play Services. The restarts appeared only after updating Services to the latest version, after a certain game demanded it.
    I then uninstalled the updates, which seemed to abolish the restarts for a few days. I then installed several other games, and now the restarts are back.
    I erased the Services cache and wiped the cache partition; to no avail.
    Having a non-updated version of Services is annoying in its own right, since many games say "Game won't run unless Google Play Services is updated". Whereupon all I need to do is tap somewhere on the screen, and the message is gone.
    What's the meaning of this? Is an updated Services required or not? How will I solve my restart problem? Can I run some debug program that will magically log what goes wrong one second before the tablet crashes? I'm still not 100% sure that it's Services.
    Is it possible at all that it's a hardware problem?
    10-22-2016 02:08 PM
  2. belodion's Avatar
    It could be that. Does the trouble persist in Safe Mode?
    Laura Knotek likes this.
    10-22-2016 02:48 PM
  3. tenenboim's Avatar
    Haven't tried, but I'm confused: how will I test this in safe mode if all the games I installed are disabled? When idle the system doesn't restart (or perhaps it does, but I've never sat in front of the idle tablet, stared at it and waited for it to restart).
    10-22-2016 03:23 PM
  4. tenenboim's Avatar
    Can nobody help with this very basic issue? My tablet is not usable...
    10-23-2016 12:44 PM
  5. nahoku's Avatar
    Random restarts are not basic in any sense of the word... or troubleshooting would be easy, wouldn't it? Could be software, hardware, or simply your battery. I've experienced this with a bad battery in my Note 4. One battery causes a random restart, while 3 others don't... and it's repeatable.
    10-24-2016 03:48 AM
  6. tenenboim's Avatar
    Okay, I more or less determined that it doesn't happen in Safe Mode. Ergo: software problem.
    Is there a logging app whose output I'll be able to read after a spontaneous restart? Will something like that help me find the problem?
    10-24-2016 02:27 PM
  1. Phone won't restart no matter what I do.
    Last Post: 10-25-2016, 06:42 AM
  2. Restarts, loops, changes settings
    Last Post: 10-22-2016, 07:51 AM
  3. Replies: 0
    Last Post: 10-21-2016, 09:57 PM
  4. Play Store not downloading until device or application restarted
    By tk-093 in forum Google Pixel & Pixel XL
    Last Post: 10-20-2016, 03:12 PM
  5. Replies: 0
    Last Post: 10-20-2016, 02:59 PM
