I normally change my wallpapers frequently.
Usually go thru an app like BackgroundsHD. It lets you set scrolling, non etc
And then I goto the wallpaper for the lock and hit set lockscreen wallpaper and that too is in the list of what wallpaper to set (i.e. Lockscreen)
Not sure if it was the app that allowed it, I don't believe so because there are several
I CAN set a wallpaper now with Pixel either thru the settigns, I can hit wallpaper or lockscreen or both. But if I set the wallpaper of one of my images with the BackgroundHD app or many others, I go back in and lockscreen is NOT an option. I would have to go up top in settings and scroll thru tons of wallpapers to find it and do it
Any help?? this could be so easy I am missing something
Also, I am very verbose and not good at explaining so forgive me
Then again you may understand me and it is just taken out of Nougat
Thank you immensely
Thank you immensely
