1. smartphonenewb's Avatar
    I downloaded facebook. and messenger .... both icons are now located at the top right of my screen next to the temperature.... everytime someone posts something or sends me a facebook message, it beeps and then puts a # next to the facebook icon. I can't seem to get these icons to close, or move... is it costing me data since they are located there and actually keeping track of all the messages/posts that come on facebook???
    Brand spankin' new smart phone owner. Samson Galaxy J3V
    10-30-2016 02:05 PM
  2. Rukbat's Avatar
    Every time something downloads to them it's costing you data (or wifi). Just long-press an icon and you should get a "remove" type of item in the menu. (The app itself, though, is probably still running. If you want it to stop accepting data, uninstall it. You can't both have it and not have it, and if you have it, and data is sent to it, it's going to accept it.)
    10-30-2016 02:33 PM
  3. smartphonenewb's Avatar
    So just signing out of facebook will not stop it from using my data?
    10-30-2016 03:16 PM
  4. ManiacJoe's Avatar
    Signing out and stopping both apps from running should stop the data use.
    10-30-2016 09:28 PM
  5. B. Diddy's Avatar
    Welcome to Android Central! You could also Restrict Background Data for that app. Go to Settings>Data Usage, select Facebook, and the select the Restrict Background Data option. When Facebook is not in the foreground (i.e., you're not actively using it), this will prevent it from using mobile data to refresh while it's paused in the background.
    10-30-2016 11:54 PM
  1. Cellular data - 5 seconds 2.5mb
    Last Post: 11-01-2016, 09:58 AM
  2. Replies: 2
    Last Post: 10-31-2016, 01:30 AM
  3. Replies: 2
    Last Post: 10-31-2016, 01:02 AM
  4. Bought at Google, but
    By Rumblee1 in forum Google Pixel & Pixel XL
    Last Post: 10-30-2016, 08:44 PM
  5. Replies: 0
    Last Post: 10-30-2016, 01:59 PM
