1. Ashraful Haq's Avatar
    Hello
    I bought a kingwear kw88 smartwatch from china. it came with baidu insteed of google services. i was trying to install google service and kingroot installed on it. but in the mean time i did not noticed that the google service version i was trying to install was for a mobile . now my watch is stuck in a bootloop where is starts and goes to a screen where i have to select from
    1. reboot system now
    2. Apply update from ADB.
    and the way to select is the power button . and up and down is volume button. as i donot have volume button on my watch i cannot do anything and been waiting for it. even i made the battery die and recharge after complete shut down. does not work still in same boot screen.
    Can any one please help me with this ?
    thank you in advance
    Edit: i tired to look for how to factory reset the watch. but it seems google still is dark about how to reset it without getting into the settings factory reset option.
    11-11-2016 07:11 AM
  2. anon(632115)'s Avatar
    A factory reset should resolve it. You will have to use Google to track down how to do this.
    11-11-2016 07:32 AM
  3. kokolo1619's Avatar
    dear sir,
    did you solve the problem how to hard reset KW88?
    I have problem - have changed display settings - now i can not use menu and can not acces anything on KW88.
    do You Know how to change that?
    11-13-2016 03:59 PM
  4. kokolo1619's Avatar
    there is nothing on Google about hard reset kw88
    11-14-2016 03:28 AM
  5. Farzad81's Avatar
    I have the same issue , have you managed to find out a solution ?
    Changed display settings - now i can not use menu and can not acces anything on KW88..
    11-25-2016 10:20 AM
  6. jamesyee's Avatar
    Hi i m james .i also have problem of conect to the phone v kw88 and ,before this i bought a cheap smartwatch the setting is very easy just connect to blue thool will connect everything,, but now this one i connected but no sms notification and can;t call out and receive calls ...please let me know how please !!
    01-07-2017 01:07 AM
  1. Replies: 1
    Last Post: 11-11-2016, 07:00 AM
  2. Replies: 1
    Last Post: 11-11-2016, 06:47 AM
  3. Replies: 1
    Last Post: 11-11-2016, 06:20 AM
  4. How to save text which has been"saved" to the CLIPBOARD.
    Last Post: 11-11-2016, 06:17 AM
  5. How can I stop slide show?
    Last Post: 11-11-2016, 04:30 AM
