1. Dmoore1188's Avatar
    Using an LG-G4 Android version 6.0. Recently my phone has started asking for reviews and giving me usefull business infomation. I want to turn these notifactions off. Example stopped at a mall yesterday to eat at the food court, I get a notifacton for the layout of the mall, useful but I don't want it. Pull over to text or use the phone, wants me give review of the business I just stopped at....ect. Sorry if this has been asked already, all the keywords gave me lots of unrelated search results.
    11-19-2016 07:59 AM
  2. ManiacJoe's Avatar
    Without knowing what is installed on your phone, the first thing I would check is to see if the "smart notice" widget is running on your home screen.
    11-19-2016 05:19 PM
  3. Mooncatt's Avatar
    I know Google Maps gives me similar notices quite a bit. Unfortunately I haven't found a way to disable those only without fully disabling all of Maps notifications.
    11-21-2016 08:19 AM
  4. srkmagnus's Avatar
    You need to open Google Now (Google app). From there open the menu - settings - Your Feed - scroll down and disable places. From there you can disable/enable settings and information you want displayed.
    Let us know if this helps.
    11-21-2016 03:30 PM
  1. Replies: 1
    Last Post: 12-05-2016, 03:58 PM
  2. How do I turn off camera roll
    Last Post: 11-18-2016, 06:07 PM
  3. Android Droid Turbo 2 will not turn on.
    Last Post: 11-18-2016, 05:54 PM
  4. my gs7edge turns to gray after few minutes.
    Last Post: 11-18-2016, 01:08 PM
