1. AC Question's Avatar
    Hello, in m status notification bar there's an icon that I don't know...
    It is made of a 3 planets orbits. Do you know which app is it?
    11-22-2016 04:51 AM
  2. chanchan05's Avatar
    What happens when you pull down the notification shade?
    11-22-2016 05:42 AM
  3. foxx01's Avatar
    Hello, in my status notification bar there's an icon that I don't recognize...
    thank you!
    11-22-2016 02:51 PM
  4. Javier P's Avatar
    Welcome to the forums. Can you get more information if you expand the notification shade? What phone do you have? In some models you can create a widget to check the notification log.
    11-22-2016 03:00 PM
  5. foxx01's Avatar
    is my dad that have this problem...I only know it is a Samsung J5...he told me it could be Smart Manager app, but I'm not sure...
    Could you help me?
    11-22-2016 03:03 PM
  6. nahoku's Avatar
    Can't you ask your dad to do as Javier P has suggested? Then he can tell you what app the notification belongs to.
    11-23-2016 12:22 AM
  7. B. Diddy's Avatar
    Threads merged
    11-23-2016 01:10 AM
  1. how can i see if my phone is fully Unrooted
    By Zero Temp in forum LG G3
    Last Post: 11-23-2016, 05:17 AM
  2. Replies: 1
    Last Post: 11-23-2016, 03:36 AM
  3. Replies: 1
    Last Post: 11-22-2016, 05:05 PM
  4. Is it still safe to use Moto g 1st gen ?
    Last Post: 11-22-2016, 01:04 PM
  5. eye icon on screen
    Last Post: 11-22-2016, 12:39 PM
