1. VanBCguy's Avatar
    Hi all;
    S7 Edge vers 6.0.1
    I seem to have lost the few important SMemos I had saved. I've never had troubles finding them before bit now it says I have none. I've followed a few threads to find a path and none of them work (i.e. - data.samsung.android.app.smemo)
    I didn't have much there but what I did have is urgently needed.
    Help?
    11-23-2016 09:10 PM
  2. SpookDroid's Avatar
    Unfortunately that's a bug that was introduced a few updates ago and users are losing notes if they weren't synced to Samsung's servers. In my case I was able to find them saved on my phone, and I was able to re-import them. Not sure the path, though, S-Notes just found them.
    11-24-2016 12:13 AM
  3. VanBCguy's Avatar
    Thanks for the reply Spook. Unfortunately, I turn up nothing with a search.
    11-24-2016 07:04 PM
  4. SpookDroid's Avatar
    Were you syncing to anything? Samsung or Evernote? If you backed up your device there or made a local back up you might be able to get those back.
    11-28-2016 12:22 PM
  1. What are the two black blobs above the notification pane?
    By minanz in forum Samsung Galaxy S7 edge
    Last Post: 11-24-2016, 05:37 PM
  2. Replies: 0
    Last Post: 11-23-2016, 09:03 PM
  3. Why are ads appearing as soon as I unlock my G4?
    By BicBoi1221 in forum Ask a Question
    Last Post: 11-23-2016, 05:56 PM
  4. Replies: 2
    Last Post: 11-23-2016, 03:29 PM
