1. silverfang77's Avatar
    If I were to get an Android tablet, could I have the same Gmail accounts and apps on it that I do on my Droid 2, or would there be a conflict?
    04-04-2011 10:14 PM
  2. silverfang77's Avatar
    Wicked sick. Would I be able to have my paid apps on as many devices as I wanted simultaneously?
    04-04-2011 10:18 PM
  3. silverfang77's Avatar
    Well, that sucks.
    Thanks.
    04-05-2011 08:46 AM
  4. ls377's Avatar
    I don't think so. You'd have to buy them on each device I think
    Well, that sucks.
    Thanks.
    Your paid apps are tied to your account, so you can use them on any device using that account without getting charged a second time.
    04-05-2011 09:21 AM
  5. silverfang77's Avatar
    Even on multiple devices simultaneously? That sounds too good to be true. :-)
    04-05-2011 09:49 AM
  6. ls377's Avatar
    It's true...you buy the app once, and any device that you put your gmail into, whether it's a second device or a replacement, will have access to those apps. The only issue you would run into is some phone apps not being compatible with a tablet, so it won't show up.
    04-05-2011 10:02 AM
  7. silverfang77's Avatar
    That is truly cool; so much better than the BS where the license is per phone. I hope it stays that way.
    04-05-2011 10:07 AM
  8. NickA's Avatar
    I hope it stays this way too. I'm constantly switching between phones and I like to have the same apps on all phones.
    04-05-2011 10:18 AM
  9. silverfang77's Avatar
    Yes, indeed. *nods gravely*
    04-05-2011 10:27 AM
Tags for this Thread
