1. Liam Yum's Avatar
    My Huawei Y635 will randomly open things, move apps on the home screen, when the screen is off! This is quite annoying and I don't know how to fix it. It happens at random times, and I keep having to sort the apps on my home screen and resize things back.
    WHAT IS HAPPENING?
    11-26-2016 12:34 PM
  2. Rukbat's Avatar
    That's all happening in the launcher - have you tried installing a different launcher and using it? (If that fixes it, you may just need to reinstall the stock launcher - which may or may not be available, depending on which phone it is.)
    11-26-2016 01:11 PM
  1. Replies: 2
    Last Post: 11-26-2016, 03:43 PM
  2. Smashed Samsung A3 2016 Screen, how can I get my files?
    Last Post: 11-26-2016, 01:49 PM
  3. Bricked my phone, but not really. How do i fix it?
    Last Post: 11-26-2016, 01:46 PM
  4. Replies: 1
    Last Post: 11-26-2016, 01:32 PM
  5. Replies: 0
    Last Post: 11-26-2016, 11:48 AM
