1. anon(9883946)'s Avatar
    Greetings!
    When I did a factory reset on my Moto X Play today, it said that my microSD card appeared to be slow. My question is, what maker/type/format of microSD card would be best & fastest for my phone?
    As always, thank you!
    12-27-2016 02:07 AM
  2. tadpoles's Avatar
    The Samsung and Sandisk Ultra are usually very good cards. Just about any SDXC card should be fine.
    12-27-2016 02:48 AM
  3. anon(9883946)'s Avatar
    Thank you tadpoles!
    12-28-2016 10:50 AM
  4. jasonandrews25788's Avatar
    02-17-2017 02:31 PM
  1. my motorola pure will not properly mount a new sd card.
    Last Post: 01-09-2017, 04:30 PM
  2. Googleplay card not activating
    Last Post: 01-09-2017, 04:29 PM
  3. MicroSD Decryption unavailable on LG G3
    Last Post: 01-09-2017, 08:43 AM
  4. Replies: 1
    Last Post: 12-27-2016, 03:10 AM
  5. How to set micro sd card as default download?
    Last Post: 12-27-2016, 01:27 AM
