1. Kowsik BaBu's Avatar
    Hello, I'm currently using Lenovo K3 Note with marshmallow 6.0 .
    In the recent weeks, I've got this problem where my YouTube app works on wifi but not on data. There is absolutely no problem with the data connection or the app. I can even visit YouTube on chrome both on data and wifi... And also, I can't log in into games while on data, only with the help of wifi... But after I log in (after started playing the game) the game works in both data and WiFi... I have read all the previously mentioned threads and tried all the mentioned solutions like turning off data restrictions, background data restrictions, removing proxy and port, resetting app preferences, uninstall and install, reboot, changing network... And every other mentioned solutions... And one friend of mine told that, the reason why I can't log in on games is that, Google services aren't working while on data... So, I also tried to change Google settings, Google services settings... Which I can't find in my phone at all... Worst problems: I can't log in into clash of clans or Pokemon go if I'm not on wifi, but once I'm logged in, both works perfectly... Also, data is being consumed by both the apps... This is a big problem and I think Google services app is messed up... I could really use a solution other than resetting my phone...
    01-04-2017 12:03 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Go to your APN settings (What is an APN, and how do I change it? | Android Central) and see if you can disable IPv6. Sometimes Google servers don't play well with IPv6, preferring IPv4 -- not sure why.
    01-04-2017 04:23 PM
  3. Kowsik BaBu's Avatar
    Glad you replied. I've disabled IPv6 in my APN and still doesn't work.
    01-05-2017 07:42 AM
  4. B. Diddy's Avatar
    Regarding the Restrict Background Data option -- you checked to make sure the YouTube app isn't individually restricted, right? It's possible to restrict data for only individual apps, rather than all of them universally.
    01-05-2017 10:51 AM
  5. Kowsik BaBu's Avatar
    Yes, I've unrestricted data for all my apps, also checked them individually... It is not only YouTube, Pokémon go, clash of clans and any app that requires Google account sign in... Doesn't seem to work... 😔😔
    01-06-2017 08:03 AM
  6. B. Diddy's Avatar
    What version of Google Play Services do you have? I'm on 10.0.84.
    01-07-2017 12:32 AM
  7. Kowsik BaBu's Avatar
    01-07-2017 08:41 AM
  8. Kowsik BaBu's Avatar
    10.0.84
    Shall I downgrade?
    01-07-2017 08:43 AM
  9. B. Diddy's Avatar
    Have you already tried Safe Mode?
    01-07-2017 11:06 PM
  10. Kowsik BaBu's Avatar
    No I haven't yet... Also I can't sign in to a new Google account while I'm on data...
    01-08-2017 12:25 AM
  1. Two months on is it worth purchasing?
    By Tmel14 in forum Samsung Gear S3
    Last Post: 01-13-2017, 08:27 AM
  2. Samsung Galaxy note 10.1 no WiFi connection
    By Tabby1323 in forum Samsung Galaxy Note 10.1
    Last Post: 01-07-2017, 12:05 PM
  3. wifi question
    By pure1500 in forum General Carrier Discussion
    Last Post: 01-04-2017, 04:29 PM
  4. galaxy s7 back button wont respond but will light up
    By Cydney Arnold in forum Samsung Galaxy S7
    Last Post: 01-04-2017, 04:27 PM
  5. Info about meteo tab on androidauto
    Last Post: 01-04-2017, 10:42 AM
