1. Droid00's Avatar
    I have a Droid RAZR M, with Android version 4.4.2. I had chrome open the other day and started to see popups/alerts: "Unfortunately <x> has stopped" where x is one of several different processes. I see these errors non-stop. The phone is pretty much unusable. Some examples of the processes that have stopped:
    com.motorola.ccc, Email, Google Play Music, com.google.process.gapps, Homescreen...
    My understanding is this type of error is usually limited to a single app and clearing the app-specific cache resolves it in some cases. However, this issue seems much worse as it's impacting multiple processes.
    I have tried:
    1.) Clearing the System Cache (on startup)
    2.) Attempted to clear the cache and data for some apps. I can see that this doesn't actually work for me (I think)... The size of the cache and data does not change after i clear it for an app (ex: chrome).
    3.) Clearing the cached Data for all apps in Settings >> Storage >> Cached Data. It's possible this isn't actually working (it's not actually clearing anything)...
    The only time I don't see these popups/alerts is for about 1 minute after boot, or when I access the notification pull down menu. Every once in while i get a few seconds to do something before they start again..
    I was also going to try do a repair using the Verizon Software Update tool
    See www.motorola.com/verizonsoftwareupdatewin. However, executing the app resulted in an error, so I put that idea aside for now (couldn't resolve it with Microsoft's suggested fix). BTW the error was CreateProcess failed; code 193, %1 is not a valid Win32 application.
    I'd really like to get the phone working without a factory reset.
    Thanks.
    01-08-2017 02:21 AM
  2. honeybun1986's Avatar
    Unfortunately this may not be the solution for you. But once I had the exact problem with my LG phone and I flashed a stock ROM. Then after that, everything was fine. :-)
    I think you should try to flash a stock firmware. Since I don't own a motorola phone, I cannot tell you the exact ways. But youtube will help you I think. :-)
    01-08-2017 07:52 AM
  1. where are the text messages file in Samsung SM-G386W
    Last Post: 01-09-2017, 05:14 PM
  2. I cant turn on wifi and bluetooth on my Zenfone 3 max
    Last Post: 01-08-2017, 05:35 AM
  3. Replies: 1
    Last Post: 01-08-2017, 03:23 AM
  4. Can't turm htc one on or off
    Last Post: 01-07-2017, 11:33 PM
  5. X96 TV box has no hdmi video signal
    Last Post: 01-07-2017, 11:19 PM
