1. Kupo15's Avatar
    I'm sure this topic has been touched upon many times over and over, but this morning, "com.amazon.avod.thirdpartyclient keeps stopping" kept repeatedly popping up. After awhile I get a notification that the SD card is missing. Tried restarting and restarting in Safe Mode, and it's still there. This is a brand new card (about 3 months old). Incidentally, Dropbox and file manager also fail to work.
    Wondering if there are any other solutions rather than factory reset or ruling this as a bad SD card. I did set up the card as internal storage, as well.
    The least I want to do is at least get the card back working, even if I have to lose the data on there.
    01-08-2017 11:41 AM
  2. treetopsranch's Avatar
    Can you try the card on a PC to see if it's working?
    01-08-2017 12:18 PM
  3. Rukbat's Avatar
    An internally formatted card is encrypted ext4, so it will have to be formatted on the PC to check it - losing everything on it.
    01-08-2017 01:54 PM
  4. jasonandrews25788's Avatar
    I think the SD Card is damaged.
    02-17-2017 02:12 PM
  1. Replies: 2
    Last Post: 01-13-2017, 11:57 AM
  2. Replies: 1
    Last Post: 01-08-2017, 01:58 PM
  3. I can't move my calendar app to my sd card please help.
    By andy a in forum General Help and How To
    Last Post: 01-08-2017, 10:39 AM
  4. default camera app missing problem in micromax a106
    Last Post: 01-08-2017, 07:19 AM
  5. Replies: 2
    Last Post: 01-08-2017, 12:31 AM
