1. Ladysovereign Sanctified's Avatar
    I need to stop this crap. I just caught trying to steel my data by holding our two cells together. I recognized of coarse right away what he was attempting to do and snatched my phone away. All suggested ways to detect and prevent this hacking would be very much appreciated. Thank you.
    01-13-2017 05:21 AM
  2. Matty's Avatar
    Best advice I can give is set a password for your SIM card, set a password for your phone and encrypt your MicroSD so it will only work in your phone in case he tries to copy things from there.
    Not sure what "hacking" he was doing, could be through your NFC or maybe through Bluetooth but if you have what I suggested above that should help to some extent. Maybe even report him to the police? Hope this helps in some way.
    A droid a day, keep the apple away.
    B. Diddy likes this.
    01-13-2017 05:39 AM
  3. Aquila's Avatar
    Ditch the roommate, use a password. Matty is correct.
    ManiacJoe, Tim1954 and B. Diddy like this.
    01-13-2017 09:12 AM
  4. Golfdriver97's Avatar
    A password is one of the better things you can do. Encrypting the SD card is another good idea, but if you don't have anything sensitive there, doing so isn't necessary.
    Mod note: thread moved to General Help & How to for better traffic.
    01-13-2017 09:47 AM
  5. spagman's Avatar
    Why is it so easy for him to get a hold of your phone?
    It would be easier for someone to steal a bone from a starving doberman..... Than to get hands on my phone.
    Tim1954, B. Diddy and bigmatt503 like this.
    01-13-2017 01:07 PM
  6. Tim1954's Avatar
    Yes, mine has a 19 digit multilingual password but good luck getting to it without all your fingers getting broken.
    Don't leave your device lying around. And get rid of this slime, who knows what else he might be stealing! Or where he might be rummaging while you're not around...
    01-13-2017 07:16 PM
  7. Tim1954's Avatar
    He may have installed some spy ware on your device too.... Get that checked our...
    01-13-2017 07:17 PM
  8. matther22xdroid's Avatar
    There are apps that take pics with the camera on your phone when the phone is messed with outside of certain parameters. Read this article and also the comments to find alot of anti snooping apps.
    http://gizmodo.com/this-anti-snoopin...cussion-region
    There are also fists at the end of each arm on your body to help prevent this as well.
    Tim1954 likes this.
    01-14-2017 05:14 AM
  9. ScottsoNJ's Avatar
    He/she would be an EX roommate very fast
    Tim1954 likes this.
    01-14-2017 10:59 PM
  1. I'm new
    By rbdmawcsc in forum Alcatel Android Phones
    Last Post: 01-13-2017, 05:48 AM
  2. Replies: 1
    Last Post: 01-13-2017, 05:37 AM
  3. Please help with 404 Error. I am clueless
    Last Post: 01-13-2017, 03:11 AM
  4. Replies: 0
    Last Post: 01-13-2017, 02:06 AM
  5. Why won't my Nexus 6p display timeout as set?
    Last Post: 01-13-2017, 01:57 AM
