can't change usb options
sanok
8
In Android 6 home screen when I swipe from top to bottom there is a USB menu (when USB is connected to PC). I can't choose any other options like file transfers MTP or photo transfers PTP, only charging is selected.
In settings -> developer options I have changed the USB configuration to MTP or PTP and rebooted but it doesn't help. I just can't transfer photos or videos to PC
ManiacJoe
Trusted Member
Aug 5, 2015
6,326
3
38
Are you using the original usb cable that came with the phone?
Does your computer recognize the phone at all as being connected?
samyblaze
