1. McLovin McBabies's Avatar
    The damn Huawei P9 kills my third party apps and services no matter how much whitelisting i make.
    from the phone manager:
    - added the required apps to the protected list.
    - power plan set to "performance".
    - installed PM plus and added the required apps to app auto-launch.
    - "keep running after the screen is off"
    from phone settings:
    - ignore battery optimization.
    What else should i do.
    Thanks.
    01-21-2017 12:38 PM
  2. Mooncatt's Avatar
    I'm not familiar with this phone or EMUI, but is it possible to fully disable whatever optimization protocol it's using? Android is designed to keep RAM full, so it's odd that a manufacturer would include anything that would arbitrarily close apps. If this is an option, then I'd just shut it down and not bother with it. Optimization apps like this and even third party apps like Clean Master are generally not recommended for this reason. They can work against the OS and can cause more problems than they fix .
    01-22-2017 07:26 AM
  1. How do I delete apps from the lock screen?
    Last Post: 01-21-2017, 02:31 PM
  2. To use icon folders or not to??
    By MsMichele in forum Samsung Galaxy Note 4
    Last Post: 01-21-2017, 12:29 PM
  3. Replies: 0
    Last Post: 01-21-2017, 12:28 PM
  4. May google apps.unfortunately stopped..in my sony mobile
  5. Replies: 0
    Last Post: 01-21-2017, 11:46 AM
