1. dulumian's Avatar
    How to resolve the subject issue in Sony Xperia C4
    01-25-2017 08:10 AM
  2. B. Diddy's Avatar
    There are many threads about the screen overlay issue -- try this one: http://forums.androidcentral.com/sam...ly-select.html
    01-25-2017 05:46 PM
  3. deviddevid's Avatar
    Screen Overlay detected problem solved:
    Follow this simple guide:
    >Settings
    >Apps
    >Option(Three Dots)
    >Click on “Draw Over Other Apps” OR “App Can Appear on Top” whichever option available in your device…
    >Now list of apps whose screen overlay is enabled will appear…
    >Disable /Turn Off For All App…
    Then Your Problem Must Be Solved…
    This is my first post on android central and I want to make my authority on Android Central..
    So please review my answer....
    04-04-2017 01:52 AM
  4. belodion's Avatar
    ^ Welcome.
    The OP of this thread seems to have abandoned it, neither acknowledging B. Diddy's reply, nor responding to it. I'll therefore do my best to answer you by saying that your post is clearly written and easy to follow. Whether it would solve the problem for all users, I don't know. But thank you.
    04-04-2017 05:40 AM
  1. Screen locks overnight - Still on wrist
    By john0038 in forum Samsung Gear S2
    Last Post: 01-29-2017, 12:42 PM
  2. Replies: 4
    Last Post: 01-25-2017, 09:10 PM
  3. Samsung Galaxy S7 Edge Black Semi Circle Dot at edge of screen
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 01-25-2017, 07:51 AM
  4. Replies: 0
    Last Post: 01-25-2017, 06:48 AM
  5. Replies: 0
    Last Post: 01-24-2017, 07:38 PM
