1. ShaggyKids's Avatar
    Hi there,
    When we lived in town and my Note 5 was connected to my WiFi I could make and receive calls. Why then would one need WiFi Calling?
    Thanks,
    Deb
    01-26-2017 11:29 AM
  2. Almeuit's Avatar
    Hi there,
    Thanks,
    Deb
    That sounds like you had a decent cell signal still so it worked. If you're in a place with low to no service but have WiFi you can use the WiFi to call / txt due to the no cell signal.
    01-26-2017 11:32 AM
  3. ShaggyKids's Avatar
    That helps a LOT, thank you
    My Note 5 does not have a WiFi calling app in the drop down from the top but the TMO phones we are testing do. So, if WiFi calling is enabled
    I can still make and receive calls on it, correct? Wait, that won't work I don't think because I think my phone has told me that I can't have hotspot and WiFi on at the same time.
    01-26-2017 11:44 AM
  4. Mizz Laura's Avatar
    My Samsung Galaxy Grand Prime days the same thing. Can't use hotspot n wifi at same time.
    ShaggyKids likes this.
    01-26-2017 02:43 PM
  5. Mizz Laura's Avatar
    My Samsung Galaxy Grand Prime says the same thing. Can't use hotspot n wifi at same time.
    01-26-2017 02:49 PM
  6. ShaggyKids's Avatar
    Are you able to make and receive calls in either case?
    01-26-2017 04:37 PM
  1. Slow WiFi Data Rate
    By Tranacria in forum Other ZTE Android Phones
    Last Post: 01-26-2017, 09:33 AM
  2. Replies: 0
    Last Post: 01-26-2017, 09:13 AM
  3. Call Volume
    By recDNA in forum LG V20
    Last Post: 01-26-2017, 08:09 AM
  4. Replies: 0
    Last Post: 01-25-2017, 08:33 PM
  5. Why can't I connect to wifi?
    Last Post: 01-25-2017, 05:02 PM
