1. AlWmX's Avatar
    So I just bought a Moto Z also known as Moto Z Droid and I updated to Nougat, and I see that its compatible with Daydream, so I start researching, as I have a generic VR headset. I discovered I could use another Android Phone to use as Daydream controller, so I used my old Sony Xperia Z3 with Marshmallow. Problem is, they both pair but they don't mantain a connection, they both disconnect a second later. Decided to test if there was an error with either the Z3 or the Moto Z. I doubted any one of both would have BT errors, as I had streamed music a few days ago from the Z3 and just had used a BT speaker on the Moto. I tested it with an old Moto RAZR D1 to see what's up with the BT of both phones. And the result is, both phones did the same thing with the D1.
    They paired to the phone, and as they established a connection, they disconnected.
    01-26-2017 09:16 PM
  1. Why did instagram randomly put pics on my brothers phone?
    Last Post: 01-27-2017, 10:56 AM
  2. How to disable screen enlarge function in galaxy phone.
    Last Post: 01-26-2017, 09:14 PM
  3. How to unblock a phone a mobile phone number
    Last Post: 01-26-2017, 09:04 PM
  4. Replies: 0
    Last Post: 01-26-2017, 08:01 PM
