1. OldGreyWolf58's Avatar
    I have actually downloaded and installed then uninstalled Aviate to try and stop this , but to no avail.
    01-27-2017 07:45 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Some other app must be responsible -- do you have any other Yahoo apps installed? How is it trying to download -- do you see an actual download progress indicator in the status bar, or do you keep getting popups asking you to install it?
    01-28-2017 01:39 AM
  3. OldGreyWolf58's Avatar
    As far as I can tell....there are no other Yahoo apps....In the notification area at the top it tell me it downloading aviate launcher....however it never actually downloads anything....i installed it a couple of months ago to see if that would stop the problem, but as soon as I deleted it the downloading message started again.
    01-31-2017 11:15 AM
  4. B. Diddy's Avatar
    When you see that notification, swipe down the notification panel and long-press the notification. Then tap App Info. What's giving you the notification?
    02-01-2017 11:58 AM
  5. OldGreyWolf58's Avatar
    OK, I think that did the trick....I didn't realize I could press and hold on the notification and see where it was coming from......so I deleted the app that was causing it.
    Thanks so much for the response and teaching me something.
    B. Diddy likes this.
    02-02-2017 09:22 AM
  1. Deciding between iphone 5s and Huawei P9 lite
    Last Post: 01-27-2017, 11:20 AM
  2. can't copy files to Huawei mate 8
    By hhajj in forum Ask a Question
    Last Post: 01-27-2017, 07:39 AM
  3. Is side loading the Pixel Launcher on my Nexus piracy?
    Last Post: 01-27-2017, 07:35 AM
  4. Why can't the SD card be left in?
    By Reed Swain in forum Chromebooks
    Last Post: 01-27-2017, 07:34 AM
  5. Replies: 0
    Last Post: 01-27-2017, 07:29 AM
