1. BlueWulf74's Avatar
    Hello All,
    I have a memory problem with my tablet. I've seen tons of similar posts, but not to the same level of severity as to what I'm seeing.
    Acer Iconia
    1.3 GHz
    1 GB RAM
    16 GB ROM
    Running Marshmallow
    After factoring the 6.32 GB storage needed for the OS, I have 9.68 GB of internal storage left. Of that, 9.59 is used up. ON WHAT????
    Apps - 2.41 GB
    Images - 269 MB
    Videos - 8 KB
    Audio - 40 KB
    Other - 30.9 MB
    Cached Data - 610 MB
    In total, this works out to less than 3.5 GB. So what is taking up the other 6 GB? It's rendered the tablet almost unusable as I've deleted as many apps from internal as I can, and I can't make enough room to download apps to move to the SD card. Right now, I can't even download updates.
    IS the 6 GB being taken up by the backup partition? If so, is there a way to move the backup to the SD?
    All images, music files and any app that can be moved has been moved to the SD card from the get go. I have almost 20gb of storage left on my 32 GB SD card.
    Any suggestions would be greatly appreciated. Or if someone can direct me a thread that already answers this issue.
    Thanks!
    01-28-2017 11:39 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Can you show us a screenshot of the Settings>Storage menu? http://forums.androidcentral.com/gen...d-central.html
    01-29-2017 01:31 AM
  1. Replies: 1
    Last Post: 01-30-2017, 03:29 PM
  2. Problem with HTC E9 Plus
    By GustavoWoltmann016 in forum More HTC Phones
    Last Post: 01-29-2017, 01:35 AM
  3. LG Stylo 2 on/off issues plus
    By MrZuLu in forum LG G5
    Last Post: 01-28-2017, 07:52 AM
  4. Those with battery issues; Try enabling data saver
    By ElronTheElder in forum Google Nexus 6
    Last Post: 01-28-2017, 06:14 AM
  5. Why do items from sd card appear on internal storage?
    By 1 9 9 7 in forum Ask a Question
    Last Post: 01-28-2017, 04:49 AM
