1. Judy android's Avatar
    I have just gotten a Samsung Galaxy S7 Active, replacing an HTC Inspire. I don't remember the name of one app I had on the Inspire that I really appreciated and that was hard to find. The app was a "bar" that went across several cells of screen space and housed a number of buttons to turn on and off WiFi, GPS, and Bluetooth. My ideal app of this type would also offer a button to turn on and off airplane mode. With it I didn't have to go in to the settings or scatter a bunch of icons around to do each thing.
    Do any of you know of a similar app?
    01-30-2017 12:16 PM
  2. Mooncatt's Avatar
    I personally don't use these kinds of widgets, but try this one. I noticed it has airplane mode in one of the screen shots.
    https://play.google.com/store/apps/d...c.easysettings
    Simply searching Play for "quick toggles" and similar terms should pull up what you're wanting.
    01-30-2017 02:26 PM
  1. Play Store slows to a crawl after 100% download
    By cjsab504 in forum Ask a Question
    Last Post: 02-02-2017, 01:34 PM
  2. Backup app on Android a good thing?
    By FinancialTitan in forum Ask a Question
    Last Post: 01-30-2017, 05:10 PM
  3. Why does my OneNote App use OneDrive instead of PDF viewer?
    Last Post: 01-30-2017, 11:15 AM
