1. LUCAS_MAX1MUS's Avatar
    The photo above is what is currently showing on the screen of my Note 4.
    I'll start at the beginning...
    About a month ago my Note 4 started really slowing down. To the stage where it would crash and restart. I performed a factory reset incase this was the cause of a dodgy app. This didn't change anything, the phone started to act up again and then proceeded to the stage of not turning on at all. However, out of curiosity, I plugged it into the charger again today and this popped up on the screen (The photo before mentioned above). Does this mean I might still be able to save my Note 4? What should I do? I can confirm that the battery, the wall charger and the cable itself are all working fine as they are all brand new. Your help would be incredibly appreciated. I can't afford a new phone and I would very much like to keep this phone if I can because it's been amazing up until now. Thank you!
    Attached Thumbnails Please help! My Note 4 wouldn't turn on for weeks and has now brought up this screen. What do I do?-16586599_1376040195782218_943501363_o.jpg
    02-04-2017 10:06 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! You could try using Odin to reinstall the stock ROM: http://forums.androidcentral.com/amb...interface.html
    02-04-2017 10:30 PM
  1. Screen protector for Mate 9 Pro.
    By cert15z in forum Huawei Mate 9
    Last Post: 02-05-2017, 09:47 AM
  2. How do I screenshot on S7 NOT using Palm Swipe?
    Last Post: 02-04-2017, 11:48 PM
  3. Replies: 1
    Last Post: 02-04-2017, 10:40 PM
  4. Replies: 1
    Last Post: 02-04-2017, 10:34 PM
