1. Tof04548159's Avatar
    By mistake i have installed some apk on my phone and after the installtion the app didnt appear on my phone so i suspected it was a virus. And as expected after the virus scan it showed:
    Malware: android-trojan/boosad.3b79b
    Path: /data/app/net.flower.driver.climate.golden-1/base.apk
    Ive gotten it removed but should i do a factory reset? Im clueless about this. Please help!!!!
    02-05-2017 11:59 PM
  2. Tim1954's Avatar
    Do not install anything with apk at the end unless you really know exactly what it is. Ever. Never. There are no accidents, you get prompted and warned repeatedly before things get installed.
    If you removed it then you should be ok, but watch your phone for strange behaviours, screen lighting up for no apparent reason, more data usage, battery life shorter... These are give away signs...
    Did I mention not installing things if you don't know what they are?
    02-06-2017 06:13 AM
  3. Golfdriver97's Avatar
    I would consider a reset to clear any files that may remain from removing the malicious app
    Tim1954 likes this.
    02-06-2017 08:42 AM
  1. New Verizon Message+ App, Contact showing up in blue font...
    Last Post: 11-09-2017, 03:21 PM
  2. how do I change the album name in my gallery
    Last Post: 02-06-2017, 05:10 PM
  3. S7 Edge how do I set keyboard as middle?
    By mrtorres009 in forum Samsung Galaxy S7
    Last Post: 02-06-2017, 02:08 PM
  4. How do you insert a sim card into a Samsung Gear S2 watch?
    Last Post: 02-06-2017, 02:45 AM
  5. Photo editing in gallery lg g4
    Last Post: 02-05-2017, 09:50 PM
