1. Father Tech's Avatar
    When I carry my phone in my pocket [Moto X 1st gen w/Android 5.1] or if I pick it up from my desk or sometimes if I just touch it, the phone often opens an arbitrary app and takes some arbitrary action in the app. How can I prevent this from happening?
    02-06-2017 11:59 AM
  2. HolySmokeJr's Avatar
    Suffering same problem now that you have reminded me. Annoying, huh? Anybody else? Hey Android, you know about this stuff, how about some fixes!
    02-06-2017 12:28 PM
  3. srkmagnus's Avatar
    What apps are opening automatically for you two? It could be notifications showing up on the home screen that are being activated.
    02-06-2017 12:54 PM
  4. Father Tech's Avatar
    If only! The apps that open are usually on my home screen. Examples:
    Google Keep opens to a random note.
    Google Maps opens and shows me restaurants near my location.
    Google Play Newstand opens to an arbitrary news article.
    02-06-2017 01:21 PM
  5. srkmagnus's Avatar
    Do you have the device password protected? That should help with this issue.
    02-06-2017 01:47 PM
  6. Father Tech's Avatar
    Yes - my phone is password protected.
    When this first started happening I thought that my screen was being rubbed by the movement of my pocket, which lead me to log off before putting my phone in my pocket. Now my phone doesn't care whether it's been logged off. It just goes and does what it wants.
    02-06-2017 02:08 PM
  7. B. Diddy's Avatar
    Do you have a screen protector or a case? If either of these are not fitting well, they might be causing ghost touches.
    02-06-2017 02:11 PM
  1. How to use old hardware (OG Droid)?
    By Casey DC in forum Ask a Question
    Last Post: 02-15-2017, 09:53 AM
  2. How's the Google Pixel Holding Up For You?
    By Alex_Hong in forum Google Pixel & Pixel XL
    Last Post: 02-08-2017, 10:05 AM
  3. Why is my phone's system taking up so much memory?!
    Last Post: 02-06-2017, 02:44 PM
  4. Replies: 2
    Last Post: 02-06-2017, 12:39 PM
  5. Download to sd
    By Neil1968bird in forum General Help and How To
    Last Post: 02-06-2017, 10:54 AM
