1. Hakdgama's Avatar
    I have a samsung galaxy tab e 9.6. The battery was fine, but now that battery percentage goes down very fast, but at like the last 5 percent, each percent takes like 30 min uses to go down 1 percentage. What can I do to make my battery work good again?
    02-12-2017 12:53 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Try recalibrating the battery sensor software by charging up to 100%, then using it normally until it shuts down automatically, then charge back up to 100%.
    02-12-2017 03:29 AM
  1. Replies: 11
    Last Post: 02-12-2017, 11:35 PM
  2. Replies: 1
    Last Post: 02-12-2017, 04:21 AM
  3. Replies: 1
    Last Post: 02-12-2017, 03:37 AM
  4. my screen is half static. how do I fix it?
    By clay451 in forum General Help and How To
    Last Post: 02-12-2017, 03:35 AM
