1. hack3rcon's Avatar
    Hello.
    I have an Android phone and I like to sell it to other but my cellphone battery have a problem and I can't turned it on. My cell phone have a pattern lock and it is not rooted too. I unplug my SD card and I want to know if in internal storage I have some personal information then the buyer can see them or not?
    Thank you.
    02-13-2017 05:15 AM
  2. Tim1954's Avatar
    content://0@media/external/file/11340 look there....
    02-13-2017 05:47 AM
  3. ChromeJob's Avatar
    Hello.
    Thank you.
    Um. Boy, a lot here. Well first you have to fix it, maybe determine if you can replace the battery yourself (look on ifixit.com for some teardowns and repair guides). Then you'll need to factory reset it to wipe the personal data you still have on there.
    THEN you're ready to sell it.
    Have you tried turning on the phone while plugged into a charger? That might help.
    Best of luck....
    02-13-2017 09:58 AM
  4. Tim1954's Avatar
    You want to keep your data really secure? Destroy the device.
    02-16-2017 10:16 PM
  5. Mooncatt's Avatar
    You'll want to encrypt it before factory resetting it, otherwise it may still be possible to find personal data left over.
    02-17-2017 07:41 AM
  6. hack3rcon's Avatar
    How ?
    02-18-2017 07:39 AM
  7. Mooncatt's Avatar
    How ?
    It should be a setting in the phone's security options. I think some are starting to come with encryption already enabled so it's not an option anymore, so double check your settings.
    02-18-2017 07:45 AM
  8. hallux's Avatar
    Once you fix the battery you'll want to PROPERLY reset it so the device becomes disassociated with your Google account so the buyer can set it up with their account.
    Jerry's article on factory reset protection will have some guidance on this: Factory Reset Protection: what you need to know | Android Central
    It's also noted that some manufacturers have their own versions of this, be sure to turn those off also.
    ChromeJob and srkmagnus like this.
    02-18-2017 08:38 AM
  9. hack3rcon's Avatar
    As I guess reset remove all data, Am I wrong?
    02-25-2017 08:46 AM
  10. ChromeJob's Avatar
    Yes. Mooncatt's suggestion is an added level of assurance that your data is removed.
    02-25-2017 09:14 AM
  1. Question about T-Mobile coverage
    By Retinella in forum T-Mobile
    Last Post: 02-13-2017, 05:01 PM
  2. New Owner - 'Mute Phone while Connected' & notification questions
    By project.in.process in forum Samsung Gear S3
    Last Post: 02-12-2017, 10:15 AM
  3. Replies: 1
    Last Post: 02-11-2017, 12:38 PM
  4. S7 Edge Rooting Question
    By Freakster1 in forum Samsung Galaxy S7 edge
    Last Post: 02-09-2017, 08:48 PM
  5. Newb Question: Is there a free way to unlock my S5?
    By Xw2X in forum Samsung Galaxy S5 Rooting, ROMs & Hacks
    Last Post: 02-09-2017, 02:35 PM
