1. Usernameofdoom's Avatar
    This is for a g5. It has been the same on both android 6 and 7. And similar issues happened when I was on t-mobile with a different phone (with t-mobile it was rare to get a connection, but was fast when I got one). This is with Sprint.
    But I many time have trouble connecting to the network, but usually can connect. Sometimes I get a very slow connection of 50kb/s or less. Other times it will got up to around 300kb/s. And very very rarely it will go up to the 1MB/s or so range. And it is very erratic. I will try to download something from the google play store and I will get these peaks and valleys were one second I have 600kb/s and the next 1 or 0 kb/s then back to 200kb/s then back down to 0 then up to 300, then 0 then 100 then 10 etc....
    Similar issues happen with wifi, but it is lesser then. WTF is going on?
    The tower for both t-mobile and sprint is only about a mile away. Also, when I was on t-mobile and in another town where t-mobile should work well, the ability to get a connection was even worse. IN TOWN. It is not the area I am in.
    02-16-2017 12:07 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Are you sure Sprint's coverage is decent in your area? If it's poor, that can certainly explain the poor speeds with mobile data.
    02-16-2017 12:37 AM
  3. Usernameofdoom's Avatar
    02-16-2017 01:52 AM
  4. belodion's Avatar
    Are there others living nearby who experience the same?
    02-16-2017 02:12 AM
  5. B. Diddy's Avatar
    Is the phone in a case?
    belodion likes this.
    02-16-2017 03:04 AM
  6. Usernameofdoom's Avatar
    I don't know if any others have the same issue. Many are on Verizon. One phone was in a case, the other was not. I would be surprised if a thin layer of plastic impeded the signal.
    02-18-2017 07:01 AM
  7. Usernameofdoom's Avatar
    For some reason the google play store is REALLY bad about it right now. And that is new.
    02-18-2017 07:17 AM
  8. Usernameofdoom's Avatar
    For some reason firefox can download okay, but the google play store cannot. It peaks up and down and then slam down to 0kb/s and does not go back up, and then the download push notice dissappears.
    02-18-2017 07:22 AM
  1. Unable to record on my LG V20
    By AC Question in forum LG V20
    Last Post: 02-23-2017, 05:31 AM
  2. Replies: 1
    Last Post: 02-16-2017, 01:05 AM
  3. Why can't I open a downloaded file
    Last Post: 02-16-2017, 01:03 AM
  4. Replies: 1
    Last Post: 02-16-2017, 01:02 AM
  5. How do i defrag my Motorola Moto phone
    Last Post: 02-16-2017, 12:39 AM
