Small apartment (681 sq. ft). T-Mobile cellspot router currently in center room of 3 rooms. Needed for my Nexus 6, iPad & Samsung Blu-Ray. Any streaming I do is mostly via the Blu-Ray. And I use OpenVPN, if that matters.
Should I replace the cellspot with...
a single Netgear Orbi?
or
a single Google WiFi?
or
a standard router like a D-Link Wireless AC1900 Dual Band?
I'm probably only iffy on the Orbi & Google cuz they don't look like routers. I'm open to any arguments or other ideas.
The cellspot will have to go if I switch to Mint SIM.
or
or
