1. Roxger's Avatar
    All I want to do is put my photos on to my pc hard drive. Iv tried Keis and smart switch. I just don't get it. Used to be so easy with previous phones. Just connect to pc and options came up.
    Now have to call samsung helpline and I still can't do it.
    It says it's backed up but where the **** do i find my photos?
    I can't find them on the pc.
    This is madness, will not buy Samsung again unless it disspenses ice!
    02-24-2017 02:18 PM
  2. SpookDroid's Avatar
    If you used Smart Switch, you should be able to see them in the back up folder from the app, but if you don't know where that is, just open the app, go to Preferences, select the back up file you want to view, click Details and make sure you DID back up Pictures in that back up. There should be a button that says 'View Backup Folder', where all your files and pictures should be available.
    02-24-2017 02:32 PM
  1. Touch screen to take pictures
    Last Post: 02-24-2017, 02:46 PM
  2. How do I delete music from my phone
    By AC Question in forum Samsung Galaxy S7
    Last Post: 02-24-2017, 02:38 PM
  3. How do i transfer my pics, files, music.etc. onto my SD card?
    Last Post: 02-24-2017, 02:35 PM
  4. Having problems using my phone keypad with automated menus
    Last Post: 02-24-2017, 02:08 PM
  5. How can i manually update software on my Lg v410
    Last Post: 02-24-2017, 01:40 PM
