1. triblogcarol's Avatar
    The newsfeed in my facebook app on both android tablets stopped working recently. It now just spins forever and never loads.
    I believe it happened about time that android system webview updated itself.
    I tried uninstalling, reinstalling, updating, clearing cache/data, etc. Nothing helps.
    Tablets are:
    Nook HD+ rooted with cyanogen 4.2.2.
    Lenovo Yoga tab 3 which has lollipop 5.1.1 on it.
    Anybody else having this problem? I did report to facebook help on both tablets, but of course, they never answer
    02-25-2017 07:30 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Moved from the Android Apps forum to the General Help forum, since the former is intended for developers to promote their apps.
    Android System Webview updates can sometimes do weird things, depending on the device and the app. Try uninstalling updates from Android System Webview, and see if the problem goes away. If it doesn, then wait until the next time that ASW is updated, then go ahead and update it. In the meantime, you could send feedback to Google about this bug.
    02-26-2017 02:03 AM
  1. Replies: 11
    Last Post: 11-23-2018, 04:18 PM
  2. Android auto not working for seat ibiza
    By Kennyboy1975 in forum Android Auto
    Last Post: 03-01-2017, 07:03 PM
  3. Why my mobile shows that device have not enough space
    Last Post: 02-25-2017, 06:14 PM
  4. In explained blue circle appears on screen
    Last Post: 02-25-2017, 03:51 AM
  5. Replies: 0
    Last Post: 02-25-2017, 03:50 AM
