1. Geek44123's Avatar
    Is it possible to upgrade my Droid 4 to a newer OS?
    Right now it has stated at 4.2 for 2 years and I would like to see it have a newer OS.
    02-28-2017 11:08 AM
  2. D13H4RD2L1V3's Avatar
    You may try loading a custom firmware, but I do not recommend it if you don't know anything about customizing Android phones on a system level as their is a very real chance that you could break your phone.
    Unfortunately, the Droid 4 will not get any more system updates, so it'll stay at 4.2 for a long time.
    02-28-2017 11:45 AM
  1. Why am I having Internet problems since Android update
    By RosL in forum Samsung Galaxy S7 edge
    Last Post: 02-28-2017, 11:25 AM
  2. Replies: 0
    Last Post: 02-28-2017, 10:46 AM
  3. Replies: 0
    Last Post: 02-28-2017, 10:13 AM
  4. Replies: 0
    Last Post: 02-28-2017, 10:02 AM
  5. How do I uninstall Android new update
    Last Post: 02-28-2017, 06:50 AM
