Help android delete my external hd without a reazon
Luigi Corrias
I own this tablet
https://www.igeekphone.com/jumper-ez...ery-os-review/
"Jumper Ezpad 4If" is a clone of "Windows Surface" SO Android 5.1 is also installed via Dual Boot
THE OS Android was in Chinese and I had translated into English by adapting even the keyboard
Last night I put the hard disk, that worked perfectly, with a 850 GB "Backup" using Android OS ..
The Android OS does not see any data ..
The HD appears perfectly formatted even though it was not shown any warning
The only folder present is LOST.DIR and is empty ..
Restart the tablet with Windows 10 still insert the external hard drive and the result is the same ..
All the missing data and the only this folder is LOST.DIR and is empty ..
Before I upgraded Windows 10 from Home to Pro ..
The hard drive had not been modified in any way
I do not understand what happened ..
I do not understand how he can recover my data ..
I could not find documentation or similar cases ..
If anyone knows what happened at least answer me ..
I have the impression that the S.O Android for some mysterious reason have deleted FAT hard disk and you have installed its LOST.DIR system folder ..
I will try with special software to rebuild the FAT and reinstall it ..
I am sure that my data is still there but all invisible ..
Please help me
Thank you very much
http://www.toshiba.eu/Contents/Toshiba_teg/EU/Others/HDD_datasheets/Canvio_Basics_Datasheet_05_2014.pdf
w8wca
