1. Maliki19's Avatar
    I did a factory reset to my prestige tablet and then I went to boot it I hit bootloader and now it is stuck in boot Moda is there a way to fix this
    If so could u please email me the way to do it thankful
    03-15-2017 03:28 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! What do you mean you hit bootloader? Did it give you a choice? Is it just stuck on that screen? If so, press and hold Power for about 10-15 seconds to force a shutdown. Then power on again normally.
    03-15-2017 07:36 PM
  3. Maliki19's Avatar
    I have a genetic android device with only a power button and all the recovery tricks won't work. Is there another less conventional method I can use to get my tablet to boot up? It operates on android 4.0.4, kernel 3.0.8+
    07-28-2020 04:24 AM
  4. B. Diddy's Avatar
    I'm afraid there's not much that you can do (nor is it really worth doing on such an old device with an obsolete version of Android that is barely supported these days). Is the main issue that you're trying to recover some important data?
    07-28-2020 12:37 PM
  1. How do I get rid of days of the week on my alarms?
    By Android Central Question in forum General Help and How To
    Last Post: 08-03-2020, 07:37 AM
  2. Where are applications in Settings?
    Last Post: 07-28-2020, 05:42 PM
  3. Lost my facebook icon from home screen can't find my facebook icon for
    Last Post: 07-28-2020, 01:08 PM
  4. My phones screen has high contrast, how can I lower it?
    Last Post: 07-27-2020, 11:24 PM
  5. why wont my controller stop blinking after the controller reset
    Last Post: 07-27-2020, 03:33 PM
