hello, just bought my first used android phone.
Its a samsung j5 sm-j5000FN, android 5.1.1 kernel 3.10.49.xxxxx
I was an iphone 3GS owner, and have no clue on androids !
I did a hard reset on the phone, and i see that it is loading some junk apps
even after hard reset. First it loads the junk apps like pizzaDE and then loads the phone
operating system.
I was told the phone is not rooted, and that i must root the phone !
Can anyone explain to me detailed and simple, how to do it, where to get the apps to run it,
what to run first and what to select so i can clean all junk from my phone, and if possible
remove any other unwanted apps please ?
Do i need wifi enabled for this ? I also have a microSD 4GB card and want to run apps or store apps on it to free more phone memory.
Would be great to hear your help.
cheers
operating system.
cheers
