1. crazypic's Avatar
    hello, just bought my first used android phone.
    Its a samsung j5 sm-j5000FN, android 5.1.1 kernel 3.10.49.xxxxx
    I was an iphone 3GS owner, and have no clue on androids !
    I did a hard reset on the phone, and i see that it is loading some junk apps
    even after hard reset. First it loads the junk apps like pizzaDE and then loads the phone
    operating system.
    I was told the phone is not rooted, and that i must root the phone !
    Can anyone explain to me detailed and simple, how to do it, where to get the apps to run it,
    what to run first and what to select so i can clean all junk from my phone, and if possible
    remove any other unwanted apps please ?
    Do i need wifi enabled for this ? I also have a microSD 4GB card and want to run apps or store apps on it to free more phone memory.
    Would be great to hear your help.
    cheers
    03-16-2017 07:00 PM
  1. Need an Android Box
    By kurtd in forum Android TV
    Last Post: 03-19-2017, 12:49 PM
  2. Replies: 3
    Last Post: 03-17-2017, 08:59 AM
  3. Notes Data can't be transferred from old Samsung S3 to New S6
    Last Post: 03-17-2017, 08:57 AM
  4. Samsung S7 updated to nougat, message contacts changed.
    By jaxsta in forum Legacy Android & Other OS's
    Last Post: 03-16-2017, 08:55 PM
  5. Replies: 1
    Last Post: 03-16-2017, 05:42 PM
