1. smithellison's Avatar
    I am using of the Blackview BV6000 from last three month, because company advertised too good features of the rugged smartphone, therefore i Purchased it. from the first day its charging very slow and dropping very quickly, wifi signal showing very weak, and data connection not easily connected. Blackview support team promised that after the updates all those problem will be solve. after the updates those problem have solved, but facing new problem like hang screen for 5-7 sec and reject the Sim frequently for that i need to restart the device 3-5 times a day.
    Now i selected AGM X1, Samsung S7 Active, and Cat S60.
    Please help me to pick one according to your professional experience.
    03-17-2017 11:37 AM
  2. B. Diddy's Avatar
    I don't know anything about the AGM or Cat phones, but in general, I'd go with well-known manufacturers with a proven track record (as well as better support), so I'd suggest the Samsung.
    03-17-2017 12:49 PM
  1. Please Help! Can I still access my data??
    By PsyintZ in forum LG G2
    Last Post: 12-02-2017, 11:02 AM
  2. Replies: 27
    Last Post: 11-15-2017, 04:56 PM
  3. Android update can't move icons and apps now???
    Last Post: 03-17-2017, 10:00 AM
  4. Please Help! Can I still access my data??
    Last Post: 03-17-2017, 08:25 AM
